Terragen 3
Website:Terragen 3
Planetside Software’s Terragen 3 is a highly realistic landscape generator used to create background images in films and games such as Star Trek: Nemesis, Stealth and The Imaginarium of Dr. Parnassus. Our script renders a single frame of a snowy mountain scene at 640 x 480 on all the available CPU execution units.
        Intel Core i7-6950X (3GHz/4.4GHz)
        DinoPC Troodon
        Overclockers UK Titan Wave
        PC Specialist Define X1
        Scan 3XS Z170 Performance GTK4
        Intel Core i7-5930K (3.5GHz/4.55GHz)
        Core i7-6700K (4GHz/4.8GHz)
        Dino PC GSX
        PC Specialist Vitrum
        Overclockers UK Titan Agent 47
        Cyberpower Infinity X55 Pro GT
        Fresh Tech Solutions 6600K Falcon R
        Overclockers UK Infin8 Nebula
        Intel Core i7-4790K (4GHz/4.8GHz)
        Utopia Pandora
        PC Specialist Apollo 703
        AMD FX-8350 (4GHz)
        CCL Elite Strix 100
          200
          300
          400
          500
          600
          700
          800
    Seconds, lower is better
Cinebench R15 64-bit
Website: www.maxon.net
Cinebench uses Maxon's Cinema 4D engine to render a photo-realistic scene of some shiny balls and weird things (we miss the motorbike). The scene is highly complex, with reflections, ambient occlusion and procedural shaders so it gives a CPU a tough workout.
As Cinema 4D is a real-world application - used on films such as Spider-Man and Star Wars - Cinebench can be viewed as a real-world benchmark.
        Fresh Tech Solutions Ultimate Collection 6700K
        DinoPC Troodon
        Utopia Pandora
        Intel Core i7-6700K (4GHz/4.8GHz)
        Dino PC GSX
        AMD FX-8350 (4GHz)
        CCL Elite Strix 100
          1000
          1500
          2000
          2500
    Score, higher is better
Power Consumption
For the power consumption tests, we  measure via a power meter at the wall. We use Prime95's smallFFT test to put the CPU under 100 percent load, while also running an instance of the Unigine Valley benchmark to load up the GPU. Idle power results are taken with the PC idling at a Windows Aero-enabled desktop.
        CCL Elite Strix 100
        Dino PC GSX
        Utopia Pandora
        DinoPC Troodon
        Cyberpower Achilles Pro 4K (4790K + GTX 780)
          200
          300
          400
          500
          600
    Watts, lower is better
